[GRASS-dev] [GRASS GIS] #1498: patch proposal: new option for
v.category to copy category values from one layer to another
trac at osgeo.org
Mon Nov 28 08:42:42 EST 2011
#1498: patch proposal: new option for v.category to copy category values from one
layer to another
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: unspecified
Keywords: v.category | Platform: Unspecified
Cpu: Unspecified |
In the attached patch againts trunk I propose an implementation of a
feature in v.category requested regularly in the mailing lists: copying
category values from one layer to another.
I don't think that it is a very invasive addition, but someone should
probably check before we apply this to trunk. It could possibly also go
into 6.5 as it doesn't break backwards compatibility.
I used the word 'transfer' for this option as the way the parser works I
needed a word with a different first letter than the others, and 'c'(opy)
was already taken by 'c'(hlayer).
On thing I did not put in is a way how to work with type=area. I just exit
with a message proposing to use type=centroid to copy category values for
areas. If someone wants to implement the same with type=area working,
please do so.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1498>
