[GRASS-dev] Fedora 16 6.4 release branch 49406 and RC2 failure
Hamish
hamish_b at yahoo.com
Mon Nov 28 15:28:12 EST 2011
Roger wrote:
> Where should I look to see which files were
> changed by r49360 on the server, so that I can
> compare with the ones I checked out?
the long way:
go to https://trac.osgeo.org/grass/browser/
or https://trac.osgeo.org/grass/ and click on the
"browse source" button on the top button bar.
follow on to grass/branches/releasebranch_6_4/
scroll down to the "> gui" row
(at this point I see Martin has checked in a fix for you one hour ago)
click on the "Rev" number for that row to get to comparative
diffs.
find the appropriate row for the change, click on the [Chgset]
number for it.
that shows you changes for that revision but only within
the gui/ dir:
https://trac.osgeo.org/grass/changeset/49409/grass/branches/releasebranch_6_4/gui
cut away the right end of the URL to see all changes of that revision.
the short way:
https://trac.osgeo.org/grass/changeset/<revision number>
the "Location:" line at the top shows that all changes are in fact
contained within the gui/wxpython/gui_modules/ dir in this case.
see also:
in a dir: svn log --limit 10
to a file: svn blame main.c
Hamish
