[GRASS-dev] Re: [GRASS-SVN] r49437 - grass/trunk/gui/wxpython
Martin Landa
landa.martin at gmail.com
Wed Nov 30 13:53:22 EST 2011
Hi Markus,
2011/11/30 Markus Neteler <neteler at osgeo.org>:
> the idea was that wx related docs should
> not be generated if GRASS
> is compiled without wxwidgets. That's why the
> condition was added.
hm, the problem is that `--with-wxwidgets` should control only if
modules which uses wxWidgets library are compiled or not. Than we
would probably need a new switch which would optionally disable
installing wxGUI code, eg. `--disable-wxgui`.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
