[GRASS-dev] Re: [GRASS-SVN] r49437 - grass/trunk/gui/wxpython
Markus Neteler
neteler at osgeo.org
Wed Nov 30 16:57:45 EST 2011
On Wed, Nov 30, 2011 at 7:53 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2011/11/30 Markus Neteler <neteler at osgeo.org>:
>> the idea was that wx related docs should
>> not be generated if GRASS
>> is compiled without wxwidgets. That's why the
>> condition was added.
> hm, the problem is that `--with-wxwidgets` should control only if
> modules which uses wxWidgets library are compiled or not. Than we
> would probably need a new switch which would optionally disable
> installing wxGUI code, eg. `--disable-wxgui`.
Apparently I don't understand the difference :)
Compiling with --without-wxwidgets I thought would be the way to
get only a "core GRASS" version without GUI.
Markus
