[GRASS-dev] Re: [GRASS GIS] #1457: Zoom in Georectify Does not Work
GRASS GIS trac at osgeo.org
Wed Oct 5 02:51:59 EDT 2011
 Reporter:  jjrambo          |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  Zoom Georectify  |    Platform:  Linux
      Cpu:  x86-32           |
Comment(by mmetz):
 Replying to [comment:4 martinl]:
 > Replying to [comment:2 mmetz]:
 > > I guess the check for alignExtent must be disabled for the
 Georectifier. Martin, is this alignExtent thing something new or at least
 newer than the Georectifier?
 > yes, see r47987. I think there is no need to disable this feature in
 georectifier(?) For quick `gcpmapdisp.py` code should be updated or
 rewrite code as I suggested and use common super-class for also for
 `mapdisp.MapFrame`. This avoid such bugs in the future and also made life
 easier for implementing similar tools, like wxGUI i.class, etc.
 I common superclass could be difficult, mainly because of the differing
 window layout managed by AUI. The status bar of the georectifier has
 entries different from the regular map display, i.e. some entries present
 in the status bar of regular map display are not present in the status bar
 of the georectifier and vice versa, e.g. "Go to GCP No." The georectifier
 uses the buffered window of wxGUI as is, but this is tightly interwoven
 with mapdisp, i.e. you do not get the one without the other one. That
 makes things difficult for georectifier, some wx.class etc. which also
 draw maps on canvas but interact somewhat differently with the maps.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1457#comment:5>
