[GRASS-dev] Re: [GRASS GIS] #1457: Zoom in Georectify Does not Work
trac at osgeo.org
Wed Oct 5 03:05:13 EDT 2011
Reporter: jjrambo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: Zoom Georectify | Platform: Linux
Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:5 mmetz]:
> > yes, see r47987. I think there is no need to disable this feature in
georectifier(?) For quick `gcpmapdisp.py` code should be updated or
rewrite code as I suggested and use common super-class for also for
`mapdisp.MapFrame`. This avoid such bugs in the future and also made life
easier for implementing similar tools, like wxGUI i.class, etc.
> I common superclass could be difficult, mainly because of the differing
window layout managed by AUI. The status bar of the georectifier has
entries different from the regular map display, i.e. some entries present
in the status bar of regular map display are not present in the status bar
of the georectifier and vice versa, e.g. "Go to GCP No." The georectifier
uses the buffered window of wxGUI as is, but this is tightly interwoven
with mapdisp, i.e. you do not get the one without the other one. That
makes things difficult for georectifier, some wx.class etc. which also
draw maps on canvas but interact somewhat differently with the maps.
OK, I didn't study the code so deeply, anyway I see some overlap in
mapdisp.py and gcpmapdisplay.py. Speaking about statusbar items, there are
some which are common, some of them differs. Common items could be handled
by this super-class.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1457#comment:6>
