[GRASS-dev] error in dialog box when adding map
Sylvain Maillard sylvain.maillard at gmail.com
Tue Oct 11 13:58:19 EDT 2011
you did it, now it's working well!
I didn't fill a bug report because I was thinking of a bug in a .po file
that I can fix, but I promise to do it next time ;)
thanks,
Sylvain
2011/10/11 Martin Landa <landa.martin at gmail.com>
> Hi,
> 2011/10/11 Sylvain Maillard <sylvain.maillard at gmail.com>:
> > I noticed an error that exist only in the french version (I test it in
> > English and German): in the dialog box when you choose a map in the
> > selection list, the result should be "your_map at your_mapset". But here it
> is
> > "your_map at de carte : your_mapset". the french translation of "mapset" is
> > "jeux de carte", so it looks like GRASS is translating and cutting the
> name
> > a a variable instead of retrieving its value ...
> > it make the dialog box totally unusable, unless you delete manually the
> > wrong part in the map name !
> > does anyone know where the selection list is coded and if there is some
> > string that could be in a .po file ? as it's happening only in french, I
> > thing the bug sould be located in a french .po file, but I wasn't able to
> > find it ...
> > this bug doesn't exist in the official 6.4.1 release, but appear in every
> > branch now (6.4-svn, 6.5 and 7)!
> hopefully fixed in r48738 (trunk) and r48739 (devbr6). Could you test it?
> Martin
> PS: It's better to fill bug-report [1], mails can become easily lost
> [1] http://trac.osgeo.org/grass/newticket
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? enlev?e...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111011/b280ea99/attachment-0001.html
