[GRASS-dev] error in dialog box when adding map
Martin Landa
landa.martin at gmail.com
Tue Oct 11 13:07:33 EDT 2011
2011/10/11 Sylvain Maillard <sylvain.maillard at gmail.com>:
> I noticed an error that exist only in the french version (I test it in
> English and German): in the dialog box when you choose a map in the
> selection list, the result should be "your_map at your_mapset". But here it is
> "your_map at de carte : your_mapset". the french translation of "mapset" is
> "jeux de carte", so it looks like GRASS is translating and cutting the name
> a a variable instead of retrieving its value ...
> it make the dialog box totally unusable, unless you delete manually the
> wrong part in the map name !
> does anyone know where the selection list is coded and if there is some
> string that could be in a .po file ? as it's happening only in french, I
> thing the bug sould be located in a french .po file, but I wasn't able to
> find it ...
> this bug doesn't exist in the official 6.4.1 release, but appear in every
> branch now (6.4-svn, 6.5 and 7)!
hopefully fixed in r48738 (trunk) and r48739 (devbr6). Could you test it?
Martin
PS: It's better to fill bug-report [1], mails can become easily lost
[1] http://trac.osgeo.org/grass/newticket
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
