[GRASS-dev] [GRASS GIS] #1475: v.overlay error (column names) under
Windows
trac at osgeo.org
Wed Oct 19 07:42:48 EDT 2011
#1475: v.overlay error (column names) under Windows
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
Attached two vectors that when used with v.overlay are causing the
following error under Windows (GRASS 6.4.2RC)
v.overlay ainput=pero at filipe atype=area alayer=1 binput=priori at filipe
btype=area blayer=1 output=over1 operator=or
Copying vector objects from vector map ...
Collecting input attributes...
DBMI-DBF driver: column name 'b_Habitat_1' truncated to 'b_Habitat_'
DBMI-DBF driver: column name 'b_Habitat_12' truncated to 'b_Habitat_'
DBMI-DBF driver error:
Unable to create table: 'create table over1 (cat integer , a_cat integer,
a_id integer, b_cat integer, b_Habitat double precision, b_Habitat_1
double precision, b_Habitat_12 double precision, b_Habitat_13 double
precision, b_Habitat_14 double precision, b_Habitat_15 double precision,
b_Habitat_16 double precision, b_Habitat_17 double precision, b_Habitat_18
double precision, b_Habitats varchar(254), b_Area_ha double precision )'
Finished with error
The problem seems to be the column names in one of the two vectors, that
after adding the "a_" prefix and the truncating due to DBF limitations.
The error causes the creation of an unclean vector
Cannot open vector over2 in mapset filipe on level 2 (topology not
available, try to rebuild topology using v.build module).
then g.remove does not have any effect when trying delete it.
Under Linux the operation do not causes the above error, but the resulting
vector misses the "offending" columns.
I guess the latter is the correct behavior in these cases so GRASS under
Windows should behave the same as under Linux.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1475>
