[GRASS-dev] [GRASS GIS] #1476: Error when deleting corrupted
vectors under Windows/osgeo4w
trac at osgeo.org
Thu Oct 20 14:03:08 EDT 2011
#1476: Error when deleting corrupted vectors under Windows/osgeo4w
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
I'm testing GRASS (6.4.2rc148715m) under Windows/Osgeo4w.
If an operation goes wrong with a vector (in my case a v.buffer operation
crashed), a corrupted vector map is created.
When refreshing the GRASS browser the following message is thrown
Cannot open vector buffer_pontos in mapset mapset_agueda on level 2
(topology not available, try to rebuild topology using v.build module).
Trying delete de vector results in
Cannot delete map buffer_pontos
command: buffer_pontos g.remove.exe
vect=buffer_pontos
I tried also the GRASS console
C:\>g.remove vect=buffer_pontos
GRASS_INFO_MESSAGE(3392,1): Removing vector <buffer_pontos>
GRASS_INFO_END(3392,1)
GRASS_INFO_WARNING(3392,2): Unable to delete file
'C:\Users\gio\Desktop\curso_QG
IS_GRASS\dados\curso\GRASS\/curso_agueda/mapset_agueda/vector/buffer_pontos/hist
GRASS_INFO_END(3392,2)
GRASS_INFO_WARNING(3392,3): couldn't be removed
GRASS_INFO_END(3392,3)
GRASS_INFO_WARNING(3392,4): <buffer_pontos> nothing removed
GRASS_INFO_END(3392,4)
Under Linux (Ubuntu, GRASS 6.4.1), the same vector map is deleted without
problems
Ticket URL: <http://trac.osgeo.org/grass/ticket/1476>
