[GRASS-dev] Re: [GRASS GIS] #1470: v.out.ascii with sql where option exports only centroids and not areas
GRASS GIS trac at osgeo.org
Thu Oct 20 12:56:39 EDT 2011
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.out.ascii  |    Platform:  Unspecified
      Cpu:  Unspecified  |
Old description:
> It's not possible to export areas selected by SQL WHERE clause.
> Example from NC data set. Let's export only lake with CAT=5109:
> v.out.ascii input=lakes at PERMANENT layer=1 output=vbuffer_fail_on_area3
> where=cat=5109 format=standard
> Output vector part:
> C  1 1
>  627457.82440791 231495.92575519
>  1     5109
New description:
 {{{ood
 Output vector part:
 C  1 1
  1     5109
Comment(by martinl):
 Replying to [comment:2 mlennert]:
 > Replying to [ticket:1470 marisn]:
 > This is logicial in the sens that only the centroid has a cat=5109. No
 boundary has this cat. So this would mean implementing a specific
 algorithm to check which boundary needs to be exported together with this
 centroid.
 Basically it could be possible. Currently `v.out.ascii` opens vector map
 on level 1 (without topology). This would require level 2 (topology). I
 can imagine special flag which writes out also areas (boundaries and
 centroids), not only centroids. The problem is that boundaries of adjacent
 areas will printed twice. I am not sure whether it's a good idea to extend
 functionality of this module in this direction. Any opinion?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:3>
