[GRASS-dev] Re: [GRASS GIS] #1470: v.out.ascii with sql where
option exports only centroids and not areas
trac at osgeo.org
Thu Oct 20 12:57:48 EDT 2011
#1470: v.out.ascii with sql where option exports only centroids and not areas
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: v.out.ascii | Platform: Unspecified
Cpu: Unspecified |
Description changed by martinl:
Old description:
> It's not possible to export areas selected by SQL WHERE clause.
> Example from NC data set. Let's export only lake with CAT=5109:
> {{{ood
> v.out.ascii input=lakes at PERMANENT layer=1 output=vbuffer_fail_on_area3
> where=cat=5109 format=standard
> Output vector part:
> C 1 1
> 627457.82440791 231495.92575519
> 1 5109
New description:
Output vector part:
C 1 1
1 5109
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:4>
