[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under
Windows/Osgeo4w
trac at osgeo.org
Fri Oct 21 04:27:35 EDT 2011
#1477: error running v.what.vect under Windows/Osgeo4w
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by lutra):
> there are some bogus, `=point` `=area` is a nonsense. How you get this
command? From wxGUI?
I'm using the QGIS plugin, but I can try the wxGUI and let you know asap.
Did v.what.vect changed since 6.4.1? On linux works fine with GRASS 6.4.1,
so an explanation may be the module have been modified and the QGIS module
GUI has not been updated.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:4>
