[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under Windows/Osgeo4w
GRASS GIS trac at osgeo.org
Mon Oct 24 14:05:05 EDT 2011
 Reporter:  lutra        |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  Vector       |     Version:  svn-trunk
 Keywords:               |    Platform:  MSWindows 7
      Cpu:  Unspecified  |
Comment(by lutra):
 > Did v.what.vect changed since 6.4.1?
 Hi, can you please help me understand where is the problem? I made a few
 tests using the same dataset/vectors and using both the wxpyhton GUI and
 the QGIS/GRASS interface.
 GRASS 6.4.2, Windows wxpython -> '''works''', command is:
 v.what.vect vector=pontos at mapset_agueda column=puppa
 qvector=freguesias at mapset_agueda qcolumn=NOME_ITA
 GRASS 6.4.1, Windows wxpython -> '''works''', command is:
 GRASS 6.4.2, Windows QGIS/GRASS -> '''doesn't work''', command is:
 v.what.vect vector=pontos at mapset_agueda =point layer=1 column=puppa
 qvector=freguesias at mapset_agueda =area layer=1 qcolumn=NOME_ITA
 the culprit does not seems to be the "=area" or "=point", as issuing the
 following trough the QGIS/GRASS CLI it '''works'''
 v.what.vect vector=pontos at mapset_agueda =point column=puppa
 qvector=freguesias at mapset_agueda =area qcolumn=NOME_ITA
 GRASS 6.4.1, Linux QGIS/GRASS -> '''works''', command is:
 Thanks in advance
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:5>
