[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under Windows/Osgeo4w
GRASS GIS trac at osgeo.org
Mon Oct 24 15:27:32 EDT 2011
  Reporter:  lutra        |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:  invalid      |    Keywords:
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Changes (by martinl):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [comment:5 lutra]:
 > GRASS 6.4.2, Windows QGIS/GRASS -> '''doesn't work''', command is:
 > v.what.vect vector=pontos at mapset_agueda =point layer=1 column=puppa
 qvector=freguesias at mapset_agueda =area layer=1 qcolumn=NOME_ITA
 > the culprit does not seems to be the "=area" or "=point", as issuing the
 following trough the QGIS/GRASS CLI it '''works'''
 This is a QGIS (or better to say GRASS plugin) bug. You should report it
 in QGIS tracker.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:6>
