[GRASS-dev] How to compile a script in GRASS
Luisa Peña
luisapena1979 at gmail.com
Mon Oct 24 04:27:31 EDT 2011
Greetings
I have installed GRASS 6.4.1 from ELGIS.argeo repository (grass.x86_64) and
installed. Also I have installed grass-devel package fromt he same
repository. What is not correc in this?
Or at least, can anyone point me where can I get all steps of this
procedure?
Thanks
Luisa
2011/10/22 Markus Neteler <neteler at osgeo.org>
> On Fri, Oct 21, 2011 at 5:31 PM, Luisa Peña <luisapena1979 at gmail.com>
> wrote:
> > Greetings
> > I have GRASS script and I want to compile it in Linux.
> > I have used other files (like r.example) as an example and when I try to
> run
> > it like (e.g. r.example)
> > cd r.example
> > make
> > I get:
> > Makefile:5: ../../include/Make/Script.make: No such file or directory
> > make: *** No rule to make target `../../include/Make/Script.make'. Stop.
> > Why am I missing? I have GRASS6.4.1 installed.
> You need to
> - either also install the grass-dev(el) package
> - or configure the source code and compile at least the
> libraries
> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111024/c304a9ba/attachment.html
