[GRASS-dev] How to compile a script in GRASS
Markus Neteler
neteler at osgeo.org
Mon Oct 24 06:16:13 EDT 2011
On Mon, Oct 24, 2011 at 10:27 AM, Luisa Peña <luisapena1979 at gmail.com> wrote:
> Greetings
> I have installed GRASS 6.4.1 from ELGIS.argeo repository (grass.x86_64) and
> installed. Also I have installed grass-devel package fromt he same
> repository. What is not correc in this?
Yes it is. The question where your module is stored. If it is outside
the GRASS source code directory then you need to tell "make" where
to find it.
# adapt path to your system:
make MODULE_TOPDIR=/usr/lib64/grass641/
Hope this helps
Markus
