[GRASS-dev] Re: [GRASS GIS] #1480: v.outlier - distinguish positive
and negative outlier filtering from lidar point clouds
trac at osgeo.org
Mon Oct 24 15:29:59 EDT 2011
#1480: v.outlier - distinguish positive and negative outlier filtering from lidar
point clouds
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.2
Component: Vector | Version: svn-develbranch6
Keywords: review | Platform: All
Cpu: All |
Comment(by mmetz):
`v.outlier` is not designed to separate first from last return of LiDAR
point clouds. The purpose of `v.outlier` is to detect true outliers, i.e.
erroneous data points. First and last returns are not erroneous data
points but valid data points. First and last returns can be separated with
the LiDAR filtering toolchain `v.lidar.*`, `r.in.xyz`, and in grass 7
`v.in.lidar` and `r.in.lidar`.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1480#comment:2>
