[GRASS-dev] Re: [GRASS GIS] #498: r.sun2 commissioning trials
trac at osgeo.org
Mon Oct 24 23:10:56 EDT 2011
Reporter: hamish | Owner: hamish
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r.sun | Platform: All
Cpu: All |
Comment(by dylan):
Here is the code used to produce the example images. Note that the beam
and diffuse radiance maps created by r.sun are clearly incorrect when
slope and aspect maps are not specified. The output looks correct when
slope and aspect are specified. The beam and diffuse radiance maps are
attached as: "beam_rad.015.jpg" / "diff_rad.015.jpg" (only elevation
given), and "sa_beam_rad.015.jpg" / "sa_diff_rad.015.jpg" (slope and
aspect given). The DEM used can be found here:
http://basho.dyndns.org/~dylan/temp/elev30.tif
g.region rast=elev30 res=30 -pa
r.slope.aspect elevation=elev30 slope=slope30 aspect=aspect30
r.sun -s --o elevin=elev30 day=15 beam_rad=beam_rad.015
diff_rad=diff_rad.015 refl_rad=refl_rad.015 glob_rad=glob_rad.015
r.sun -s --o elevin=elev30 slopein=slope30 aspin=aspect30 day=15
beam_rad=sa_beam_rad.015 diff_rad=sa_diff_rad.015 glob_rad=sa_glob_rad.015
refl_rad=sa_refl_rad.015
Ticket URL: <https://trac.osgeo.org/grass/ticket/498#comment:19>
