[GRASS-dev] configure.in: quotation marks
Martin Landa landa.martin at gmail.com
Tue Oct 25 13:47:14 EDT 2011
2011/10/25 Glynn Clements <glynn at gclements.plus.com>:
> To prevent ${prefix} from being expanded in the resulting
> Platform.make file.
thanks for the clarification.
>> the result is
>>  Installation directory:      ${prefix}/grass-7.0.svn
>> which is not really informative.
>> I would suggest to remove these quotation marks in configure.log.
> The current behaviour is intentional; it allows e.g.
> "make install prefix=..." to work as expected.
OK, change bellow should harmless, right?
-LOC_MSG([  Installation directory:      ${INSTDIR}])
+if test -n "$MACOSX_APP" ; then
+   LOC_MSG([  Installation directory:
${prefix}"/GRASS-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.app/Contents/MacOS"])
+else
${prefix}"/grass-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}"])
+fi
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
