[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under Windows/Osgeo4w
GRASS GIS trac at osgeo.org
Thu Oct 27 17:28:30 EDT 2011
  Reporter:  lutra        |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  major        |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Comment(by martinl):
 Replying to [comment:12 lutra]:
 > The problem is not only the lack of full time maintainers for the plugin
 (a void that we -Faunalia- somehow fill), but also the lack of
 communication between the two teams, QGIS and
 Well, the lack of maintainer is a main problem ... I am afraid that such
 maintainer needs to be found in QGIS community.
 > GRASS. When something changes in GRASS (a module, or as in this case an
 important core feature) it would be better to drop a line to the qgis-dev
 mailing list, so we can catch up. ;) cheers
 Please bear in mind that in GRASS 6 there should be no changes which
 brakes backward compatibility. So you can hardly expect such announcements
 even in grass-dev ML.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:13>
