[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under
Windows/Osgeo4w
trac at osgeo.org
Thu Oct 27 17:46:28 EDT 2011
#1477: error running v.what.vect under Windows/Osgeo4w
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Resolution: | Keywords:
Platform: MSWindows 7 | Cpu: Unspecified
Comment(by lutra):
> Well, the lack of maintainer is a main problem ... I am afraid that such
maintainer needs to be found in QGIS community.
Yes, we know. Is also for this reason that probably the best choice will
be to move GRASS into the new processing/analytical framework, and after
the porting to deprecate the plugin. But until then we need to keep alive
the plugin because -as it is obvious- who needs to make GIS analysis
within QGIS needs most of the times to use also GRASS.
> Please bear in mind that in GRASS 6 there should be no changes which
brakes backward compatibility. So you can hardly expect such announcements
even in grass-dev ML.
Ok. But at least a few modules have changed (ex: v.generalize) and we
realized it just when we used the module after QGIS have been recompiled
against the new GRASS release. Then we had to change the module GUI in the
plugin, and had to tell users to use trunk/master instead of the stable
release... not a big deal, but not straightforward.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:14>
