[GRASS-dev] GRASS 7 scripts overhaul
Markus Metz
markus.metz.giswork at googlemail.com
Mon Sep 5 03:27:51 EDT 2011
Markus Neteler wrote:
> Hi,
> I have tested almost all GRASS 7 scripts and fixed a lot of them (mostly
> broken in the parser part).
> To all relevant (most) I have added North Carolina examples for easier
> testing.
> This set of modules I did not manage to fix:
> * db.in.ogr
> -> it does not, as programmed, delete the empty geometry and the cat column
fixed
> * d.rast.leg
> -> messy output, at least in wx0
fixed by Michael Barton
> * i.in.spotvgt
> -> NameError: global name 'string' is not defined
fixed
> * i.spectral
> -> no more errors but also no output
worksforme
> * r.out.xyz (trying to export to elev_lid792_1m.csv)
> -> File "/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/scripts/r.out.xyz",
> line 42, in main
> outf = file(output)
> IOError: [Errno 2] No such file or directory: 'elev_lid792_1m.csv'
fixed. BTW, r.out.xyz is nothing more than r.stats -1gn
Markus M
