[GRASS-dev] Re: graphical modeler results
Martin Landa
landa.martin at gmail.com
Tue Sep 6 06:21:26 EDT 2011
2011/9/3 Michael Barton <Michael.Barton at asu.edu>:
> Input from an existing map shows up a oval with arrow to command module. But
> module taking output from another module doesn't show any graphical
> connection. There is no way to draw a graphical connection from one
> component of a model another component.
The first module produces output (data), so
module (action) ->data (eg. raster map) -> module (action)
> AFAICT, at the button with the mouseover text of "define relation between
> data and action items" does nothing graphical. It works sporadically, and
> when it does, it seems to generate data ovals and connect them to the
> command boxes. But these must be defined in the command item/grass module
> AFAICT.
It should add connection between items (line with arrow). At the
beginning the modeler has not been design to define relations
manually, they should be updated based on action parameters you enter.
Speaking about manual definition of relation you can expect some bugs,
please report them on trac (with reproducible examples).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
