[GRASS-dev] Re: graphical modeler results
Michael Barton
Michael.Barton at asu.edu
Tue Sep 6 13:19:07 EDT 2011
Thanks for the enhancements. I'll test. Are these backported to all versions or just in 6.5 for now?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 6, 2011, at 3:21 AM, Martin Landa wrote:
> Hi,
> 2011/9/3 Michael Barton <Michael.Barton at asu.edu>:
>> Input from an existing map shows up a oval with arrow to command module. But
>> module taking output from another module doesn't show any graphical
>> connection. There is no way to draw a graphical connection from one
>> component of a model another component.
> The first module produces output (data), so
> module (action) ->data (eg. raster map) -> module (action)
>> AFAICT, at the button with the mouseover text of "define relation between
>> data and action items" does nothing graphical. It works sporadically, and
>> when it does, it seems to generate data ovals and connect them to the
>> command boxes. But these must be defined in the command item/grass module
>> AFAICT.
> It should add connection between items (line with arrow). At the
> beginning the modeler has not been design to define relations
> manually, they should be updated based on action parameters you enter.
> Speaking about manual definition of relation you can expect some bugs,
> please report them on trac (with reproducible examples).
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
