[GRASS-dev] Re: [GRASS-SVN] r48158 - grass/branches/releasebranch_6_4/db/drivers/sqlite
Martin Landa landa.martin at gmail.com
Tue Sep 6 11:57:08 EDT 2011
2011/9/6  <svn_grass at osgeo.org>:
> Author: mmetz
> Date: 2011-09-05 23:48:56 -0700 (Mon, 05 Sep 2011)
> New Revision: 48158
> Modified:
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/create_table.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/cursor.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/db.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/describe.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/driver.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/error.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/fetch.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/index.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/listtab.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/main.c
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/proto.h
>   grass/branches/releasebranch_6_4/db/drivers/sqlite/select.c
> Log:
> sqlite driver: fix for #548 and related
SQLITE_IOERR_BLOCKED is not defined in older Sqlite versions (e.g.
3.3.8). Hopefully fixed in r48167.
Martin
BTW: trunk is no affected...
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
