[GRASS-dev] Re: [GRASS-SVN] r48158 -
grass/branches/releasebranch_6_4/db/drivers/sqlite
Markus Metz
markus.metz.giswork at googlemail.com
Wed Sep 7 04:29:37 EDT 2011
On Tue, Sep 6, 2011 at 5:57 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2011/9/6 <svn_grass at osgeo.org>:
>> Author: mmetz
>> Date: 2011-09-05 23:48:56 -0700 (Mon, 05 Sep 2011)
>> New Revision: 48158
>> Modified:
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/create_table.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/cursor.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/db.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/describe.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/driver.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/error.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/fetch.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/index.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/listtab.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/main.c
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/proto.h
>> grass/branches/releasebranch_6_4/db/drivers/sqlite/select.c
>> Log:
>> sqlite driver: fix for #548 and related
> SQLITE_IOERR_BLOCKED is not defined in older Sqlite versions (e.g.
> 3.3.8). Hopefully fixed in r48167.
Thanks! I have simplified usage of the sqlite busy handler, no more
#if ... #else needed.
Markus M
