[GRASS-dev] v.bd.addtable
Roger Bivand Roger.Bivand at nhh.no
Fri Sep 16 02:27:20 EDT 2011
On Thu, 15 Sep 2011, Martin Landa wrote:
> Hi,
> 2011/9/15 Roger Bivand <Roger.Bivand at nhh.no>:
>> #% type: integer
>> is missing in the 6.4 release branch for the interface description of layer
> fixed in r48304.
Thanks, see below.
>> in v.db.addtable around line 36. It is in trunk, and in 6.4.1 released.
>> Without it, the type is inferred to be string.
> Note that in GRASS7 layer is a string. It supports layer names (not
> only layer numbers) and OGR layer names when accessing external data
> directly using OGR [1].
It is in v.in.ogr etc. But in trunk/scripts/v.db.addtable/v.db.addtable.py
line 35 is #% type: integer for layer - was this intended?
> v.db.addtable --interface-description
         <parameter name="layer" type="integer" required="no" multiple="no">
                 <description>
                         Layer number where to add new attribute table
                 </description>
                 <default>
                         1
                 </default>
                 <guisection>
                         Definition
                 </guisection>
         </parameter>
> v.to.db --interface-description
         <parameter name="layer" type="string" required="yes"
multiple="no">
                 <label>
                         Layer number or name (write to)
                 </label>
                 <description>
                         A single vector map can be connected to multiple
database tables. This number determines which table to use. Layer name for
direct OGR access.
                 </description>
                 <gisprompt age="old" element="layer" prompt="layer" />
                 <default>
                         1
                 </default>
         </parameter>
The 6/7 change here breaks spgrass6 and forces version check, so I'd
rather I could rely on layer always being integer in 6 and string in 7
everywhere it occurs.
Roger
> Martin
> [1] http://grass.osgeo.org/wiki/Working_with_external_data_in_GRASS_7#Direct_access_to_external_data
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
