[GRASS-dev] v.bd.addtable
    Martin Landa
    landa.martin at gmail.com
    Fri Sep 16 04:27:37 EDT 2011
2011/9/16 Roger Bivand <Roger.Bivand at nhh.no>:
>> Note that in GRASS7 layer is a string. It supports layer names (not
>> only layer numbers) and OGR layer names when accessing external data
>> directly using OGR [1].
> It is in v.in.ogr etc. But in trunk/scripts/v.db.addtable/v.db.addtable.py
> line 35 is #% type: integer for layer - was this intended?
yes, it's an exception, layer number must be defined somehow.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
