[GRASS-dev] Re: [GRASS GIS] #957: v.voronoi has extra lines in output
GRASS GIS trac at osgeo.org
Tue Sep 20 06:49:55 EDT 2011
 Reporter:  helena     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.2
Component:  Vector     |     Version:  svn-develbranch6
 Keywords:  v.voronoi  |    Platform:  All
      Cpu:  All        |
Comment(by hamish):
 > Replying to [comment:11 hamish]:
 > > I'm not sure where the %.14g is coming from, as
 > > lib/gis/wind_format.c writes using %.15g.
 Replying to [comment:14 mmetz]:
 > Not for real projections, at least not for nc_spm_08 with
 > projection: 99 (Lambert Conformal Conic) because full %.15g
 > precision is only used when projection == -1, otherwise %.8f is
 > used. See
 https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/wind_format.c#L33
 ah, right.. so it's %.8f not %.14g. FWIW I added that -1 for "full"
 precision* in r37725 as some modules were lying to G_format_*() about not
 being lat/lon (when they really were) to get decimal output instead of
 D:M:S, with rather unfortunate results.
 [*] (%.15g doesn't quite show full IEEE double, but the max without
 partial-noise bits)
 assuming that projected coords are either in feet or meters, I'm happy
 enough with 10 nanometer precision. GPS and projection math will take a
 very long time to catch up with that. Even %.15g won't match what's in the
 vector's bbox, and again I wonder out loud if this is worth worrying
 about, or if it should just be declared a feature in the v.voronoi help
 page.
 see also #123.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:15>
