[GRASS-dev] Re: [GRASS GIS] #1189: wingrass: 'g.region -l' fails when using a NTv2 grid file (was: wingrass: 'g.region -l' fails)
GRASS GIS trac at osgeo.org
Tue Sep 20 07:06:35 EDT 2011
 Reporter:  hamish                    |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  critical                  |   Milestone:  6.4.2
Component:  Packaging                 |     Version:  svn-develbranch6
 Keywords:  wingrass, g.region, NTv2  |    Platform:  MSWindows XP
      Cpu:  x86-32                    |
Changes (by hamish):
  * keywords:  wingrass, g.region => wingrass, g.region, NTv2
  * milestone:  6.4.1 => 6.4.2
Comment:
 - bug still present in wingrass native 6.4.svn r48373 (Sept 2011) +
 spearfish.
  - $PROJ_LIB/conus file exists.
  - assume you'll get the same error with any projection which uses a NTv2
 grid file.
  - the missing $GISBASE/etc/nad/proj_def.dat file is in $PROJ_LIB.
  - copying proj_def.dat into $GISBASE/etc/nad/ gets a bit further, but
 still breaks with an unquoted pathname error. (see next post)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1189#comment:12>
