[GRASS-dev] Re: [GRASS GIS] #957: v.voronoi has extra lines in output
GRASS GIS trac at osgeo.org
Tue Sep 20 08:09:09 EDT 2011
 Reporter:  helena     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.2
Component:  Vector     |     Version:  svn-develbranch6
 Keywords:  v.voronoi  |    Platform:  All
      Cpu:  All        |
Comment(by hamish):
 Replying to [comment:16 mmetz]:
 > See comment:13 for a suggestion
 (thanks, I'd missed that)
 > > Therefore it may be a good idea to do the adjustment that
 > > g.region currently does in trunk/general/g.region/main.c#L549
 > > and following lines not only for window.north == window.south
 > > etc. but always, to make sure that all vector features are
 > > really inside the current region?
 By "always" you mean just when used with vect=, right? :)
 The idea to round out by 1/2 a grid cell in each direction seems ok at
 first, but I speculate about what the problems might be:
  - as res= is typically not set with vect=, what happens if original res
 is quite large but vector bbox is very small? you get a big region as a
 result when you wanted one orders of magnitude smaller.
  - what if you have a series of vector points broken up by region (lidar
 1km x 1km chunk files) and want to patch their bboxes together? would you
 be better/worse/no worse than now?
 perhaps it is better to expand by some other proportional amount? like the
 lesser of 1/2 a grid cell, or +/- (n-s)*1e-n ?  (where n=6..15), or +/-
 GRASS_EPSILON and change the WIND file (and thus all other G_format_*())
 to record to useless/impracticable/wasteful precision?
 or hardcode the +/- 0.00000001 with a note that it should match the
 precision in format_double()?
 open to suggestions,
 Hamish
 ps- it is wonderful that this longstanding v.voronoi bug is near to being
 fixed!
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:17>
