[GRASS-dev] [GRASS GIS] #1452: wingrass wx location wizard doesn't ask for datum transform options
GRASS GIS trac at osgeo.org
Tue Sep 20 08:19:16 EDT 2011
 Reporter:  hamish                         |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  critical                       |   Milestone:  6.4.2
Component:  Projections/Datums             |     Version:  svn-releasebranch64
 Keywords:  wingrass, location wizard, wx  |    Platform:  MSWindows XP
      Cpu:  x86-32                         |
 with latest 6.4.svn wingrass, if I create a new location with the wx
 location wizard, it never asks me for which datum transform parms I want
 to use, and applies one choice on my behalf. :-(
 Using g.setproj from the Msys rxvt prompt doesn't work well (you need to
 know what the next prompt is going to ask as you don't see the prompt --
 perhaps a missing fflush()?) so it is very hard to select to use a grid
 file, and in some parts of the world it is rather critical that you do
 that.
 example: proj=nzmg datum=nzgd49 should give you 3 choices.
 same trouble if you go by epsg code <27200>.
 on linux it works. related to #1189?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1452>
