[GRASS-dev] Re: [GRASS GIS] #1452: wingrass wx location wizard
doesn't ask for datum transform options
trac at osgeo.org
Tue Sep 20 17:30:00 EDT 2011
#1452: wingrass wx location wizard doesn't ask for datum transform options
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: wingrass, location wizard, wx | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by martinl):
Replying to [ticket:1452 hamish]:
> example: proj=nzmg datum=nzgd49 should give you 3 choices.
> same trouble if you go by epsg code <27200>.
> on linux it works. related to #1189?
are you sure that it works on GNU/Linux, testing G65
g.proj epsg=27200 datumtrans=-1
gives no output.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:1>
