[GRASS-dev] Re: [GRASS GIS] #1424: Profile tool always casts to
integers (incl. csv output)
trac at osgeo.org
Fri Sep 23 00:01:25 EDT 2011
#1424: Profile tool always casts to integers (incl. csv output)
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: profile tool, precision | Platform: All
Cpu: All |
Comment(by hamish):
basic patch added to the ticket. But before applying in svn:
`grass.raster_info(raster)['datatype']`
should be used to choose export precision based on the raster map's type,
something like:
@@ -585,9 +585,18 @@
message = _("Unable to open file <%s>
for writing.") % pfile,
caption = _("Error"), style = wx.OK |
wx.ICON_ERROR | wx.CENTRE)
return False
+ rast_type = grass.raster_info(raster)['datatype']
+ if rast_type == 'CELL':
+ write_fmt = '%.3f,%d\n'
+ if rast_type == 'FCELL':
+ write_fmt = '%.3f,%.7g\n'
+ if rast_type == 'DCELL':
+ write_fmt = '%.3f,%.15g\n'
for datapair in r['datalist']:
- file.write('%d,%d\n' %
(float(datapair[0]),float(datapair[1])))
+ file.write(write_fmt %
file.close()
dlg.Destroy()
(vs trunk; untested)
... but why are we doing that at all? for the .csv export why not just re-
run r.profile and save to the output= file directly, with all the above
stuff already taken care of? no risk of introducing aliasing or bugs if we
produce that straight from the source + it would make the code a bit
simpler.
a good test for this is to go into Spearfish, and prepare a limited range
map:
g.region rast=elevation.dem
r.mapcalc "elev_1k = elevation.dem / 1000.0"
r.info -r elev_1k
min=1.066
max=1.84
then pull that into a lat/long location with r.proj. So both map units
(decimal degrees) and z-values will show up as obviously wrong if
something gets cast to an integer.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1424#comment:5>
