[GRASS-dev] Re: [GRASS GIS] #335: export floats and doubles with
correct precision
trac at osgeo.org
Fri Sep 23 00:19:48 EDT 2011
#335: export floats and doubles with correct precision
Reporter: hamish | Owner: grass-dev@…
Type: task | Status: new
Priority: critical | Milestone: 6.4.1
Component: Default | Version: svn-develbranch6
Keywords: precision | Platform: All
Cpu: All |
Comment(by hamish):
something thing to keep in mind as we work through these: GRASS's
processing modules can be very(!) useful for processing imagery from
scanning electron microscopes. Typical pixel resolution for that might be
1 micron. aka the map units aren't necessarily in degrees, meters, or some
flavor of feet.
at the other end of things, for star catalog az,el,distance point data
projected from a lat/lon import the map units might be parsec or light-
years. (I suspect r.mapcalc et al. would also be highly useful for
processing large telescope images)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/335#comment:17>
