[GRASS-dev] GsoC2012: High level map interaction with python
Sören Gebbert
soerengebbert at googlemail.com
Wed Apr 4 04:46:49 EDT 2012
Hi Pietro,
this is an interesting and very useful submission. A numpy matrix
interface would be a valuable addition, but as Markus Metz said, we
need also direct row access without reading the whole raster or vector
map into the memory.
Actually with the vtk-grass-bridge there is already an object
orientated interface to the grass raster, vector and voxel libraries
providing convenient high level access classes and methods for C++,
Java and Python[1]. You may orient on this interface when designing
the Python GRASS classes?
Best regards
Soeren
[1] http://code.google.com/p/vtk-grass-bridge
Example vector and raster processing in C++, Java and Python:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Cxx/v.sample.rast.cxx
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Java/v_sample_rast.java
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Python/v.sample.rast.py
vtk-grass-bridge Python unit tests:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Raster/Testing/Python/GRASSRasterMapReaderWriterTest.py
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Vector/Testing/Python/GRASSVectorMapTopoReaderWriter.py
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Raster3d/Testing/Python/GRASSRaster3dMapReaderWriterTest.py
2012/4/1 Pietro <peter.zamb at gmail.com>:
> Hi everyone!
> I'm Pietro Zambelli a ph.D student of Trento University, I would like
> to apply to the GSoC, my idea in short is: extend the python GRASS API
> to make it more pythonic :-).
> I would like to interact with region, raster and vector maps as
> object, using and interacting with the map and the other GRASS
> functionality in a more higher and abstract way.
> For people used to `numpy` I would like to interact with the map with
> the same simplicity that I interact with matrix using `numpy`.
> For curious people, that want to understand my insane idea I add a new
> page in the Wiki [0] to try to explain what I mean. I have used the
> python doctest [1]: to give an brief idea of how we could interact
> with the new python module, and in case of consensus, as the basis for
> a test-driven development approach for the GSoC.
> There are many aspect that could be improved and that must be
> resolved, I try to highlight possible problems. But, of course, I need
> some help to find out more and to understand if the idea, is or not,
> good to contribute to the great GRASS software.
> Please feel free to critique, add new examples, raise problems,
> doubts, etcetera. In particular I would like to invite all developers
> to check to find incoherence/inconsistency with the GRASS and/or
> Python philosophy[2].
> Any suggestions and criticism are more than welcome!
> Pietro
> [http://grass.osgeo.org/wiki/GRASS_SoC_Ideas_2012/High_level_map_interaction]
> [http://docs.python.org/library/doctest.html]
> [http://www.python.org/dev/peps/pep-0020/]
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
