[GRASS-dev] Re: [GRASS GIS] #1268: r.out.vtk does not work as
desired for RGB images
trac at osgeo.org
Wed Apr 4 06:52:25 EDT 2012
#1268: r.out.vtk does not work as desired for RGB images
Reporter: voncasec | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-releasebranch64
Resolution: invalid | Keywords: vtk
Platform: Linux | Cpu: x86-64
Changes (by neteler):
* status: new => closed
* resolution: => invalid
Comment:
Replying to [ticket:1268 voncasec]:
> r.out.vtk does not allow a user to export an RGB series of images to vtk
format without specifying a required image as well.
> For example, running r.out.vtk for an rgb series, as described in the
user manual, returns the follwing:
> r.out.vtk rgbmaps=Landsat_NIR,Landsat_Red,Landsat_Green
elevation=elevation.10m output=/tmp/out.vtk
> ERROR:
> Parameter 'input' (Name of input raster map(s)) is missing.
For a working example (the input map is the elevation map), see
http://grass.osgeo.org/wiki/GRASS_and_Paraview#RGB_visualization
I am not sure that this is a valid bug report. I have improved the
manual page of r.out.vtk (for all GRASS versions):
http://grass.osgeo.org/grass64/manuals/html64_user/r.out.vtk.html
Closing, feel free to reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1268#comment:1>
