[GRASS-dev] errors in compiling grass6.4 in ubuntu 11.10
Hui Peng
penghui3040 at gmail.com
Wed Apr 11 19:42:53 EDT 2012
There are some errors when I compiled Grass 6.4 in Unbuntu 11.10.
Errors in:
/usr/local/src/grass64_release/lib/ogsf
/usr/local/src/grass64_release/lib/nviz
/usr/local/src/grass64_release/misc/m.nviz.image
/usr/local/src/grass64_release/visualization/nviz
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
I went to /usr/local/src/grass64_release/lib/ogsf and run 'make'.
gcc -I/usr/local/src/grass64_release/dist./include -g -fPIC
-DPACKAGE=\""grasslibs"\" -I/usr/include/gdal -DPACKAGE=\""grasslibs"\"
-I/usr/include/libavcodec -I/usr/include/libavformat
-I/usr/include/libswscale -I/usr/local/src/grass64_release/dist./include -o
OBJ./gsd_img_mpeg.o -c gsd_img_mpeg.c
gsd_img_mpeg.c: In function ‘add_video_stream’:
gsd_img_mpeg.c:69:21: error: ‘CODEC_TYPE_VIDEO’ undeclared (first use in
this function)
gsd_img_mpeg.c:69:21: note: each undeclared identifier is reported only
once for each function it appears in
gsd_img_mpeg.c: In function ‘open_video’:
gsd_img_mpeg.c:161:5: warning: ‘avcodec_open’ is deprecated (declared at
/usr/include/libavcodec/avcodec.h:3650) [-Wdeprecated-declarations]
gsd_img_mpeg.c: In function ‘write_video_frame’:
gsd_img_mpeg.c:218:15: error: ‘PKT_FLAG_KEY’ undeclared (first use in this
function)
gsd_img_mpeg.c: In function ‘gsd_init_mpeg’:
gsd_img_mpeg.c:304:9: warning: assignment makes pointer from integer
without a cast [enabled by default]
gsd_img_mpeg.c:307:6: warning: assignment makes pointer from integer
gsd_img_mpeg.c:315:8: warning: assignment makes pointer from integer
gsd_img_mpeg.c:336:5: warning: ‘av_set_parameters’ is deprecated (declared
at /usr/include/libavformat/avformat.h:1363) [-Wdeprecated-declarations]
gsd_img_mpeg.c:341:5: warning: ‘dump_format’ is deprecated (declared at
/usr/include/libavformat/avformat.h:1485) [-Wdeprecated-declarations]
gsd_img_mpeg.c:350:2: warning: ‘url_fopen’ is deprecated (declared at
/usr/include/libavformat/avio.h:278) [-Wdeprecated-declarations]
gsd_img_mpeg.c:357:5: warning: ‘av_write_header’ is deprecated (declared at
/usr/include/libavformat/avformat.h:1421) [-Wdeprecated-declarations]
gsd_img_mpeg.c: In function ‘gsd_close_mpeg’:
gsd_img_mpeg.c:442:2: warning: ‘url_fclose’ is deprecated (declared at
/usr/include/libavformat/avio.h:279) [-Wdeprecated-declarations]
make: *** [OBJ./gsd_img_mpeg.o] Error 1
I went to /usr/local/src/grass64_release/lib/nviz and run 'make'.
gcc -shared -o /usr/local/src/grass64_release/dist./lib/
libgrass_nviz.6.4.3svn.so -L/usr/local/src/grass64_release/dist./lib
-Wl,--export-dynamic -L/usr/lib64
-Wl,-rpath-link,/usr/local/src/grass64_release/dist./lib
OBJ./change_view.o OBJ./cplanes_obj.o OBJ./draw.o OBJ./exag.o
OBJ./lights.o OBJ./map_obj.o OBJ./nviz.o OBJ./position.o OBJ./render.o
-lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
-lgrass_bitmap.6.4.3svn -lgrass_linkm.6.4.3svn -lgrass_vect.6.4.3svn
-lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn
-lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn
-lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_dig2.6.4.3svn
-lgrass_rtree.6.4.3svn -lgrass_dgl.6.4.3svn -lgrass_rtree.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_dbmiclient.6.4.3svn
-lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
-lz -L/usr/lib -lgdal1.7.0 -lgeos_c -ltiff -lavutil -lavcodec
-lavformat -lgrass_sites.6.4.3svn -lgrass_datetime.6.4.3svn
-lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_g3d.6.4.3svn
-lgrass_ogsf.6.4.3svn -lgrass_bitmap.6.4.3svn -lgrass_linkm.6.4.3svn
-lgrass_g3d.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
-lgrass_sites.6.4.3svn -lgrass_datetime.6.4.3svn -lgrass_dbmibase.6.4.3svn
-lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_vect.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_vect.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lm -lSM -lICE -lX11
-L/usr/include/GL -lGL -L/usr/include/GL -lGLU
/usr/bin/ld: cannot find -lgrass_ogsf.6.4.3svn
collect2: ld returned 1 exit status
make: *** [/usr/local/src/grass64_release/dist./lib/
libgrass_nviz.6.4.3svn.so] Error 1
I don't know how to deal with these errors. Is there anyone can help me?
Thank you so much.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120411/77bc7199/attachment.html
