[GRASS-dev] errors in compiling grass6.4 in ubuntu 11.10
Maris Nartiss maris.gis at gmail.com
Thu Apr 12 02:06:37 EDT 2012
Hello,
please provide exact ./configure call and information about libavcodec
(ffmepg) version installed on to Your system.
Maris.
2012. gada 12. aprīlis 02:42 Hui Peng <penghui3040 at gmail.com> rakstīja:
> Hi,
>    There are some errors when I compiled Grass 6.4 in Unbuntu 11.10.
> Errors in:
> /usr/local/src/grass64_release/lib/ogsf
> /usr/local/src/grass64_release/lib/nviz
> /usr/local/src/grass64_release/misc/m.nviz.image
> /usr/local/src/grass64_release/visualization/nviz
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> I went to /usr/local/src/grass64_release/lib/ogsf and run 'make'.
> gcc -I/usr/local/src/grass64_release/dist./include  -g    -fPIC
> -DPACKAGE=\""grasslibs"\" -I/usr/include/gdal     -DPACKAGE=\""grasslibs"\"
>    -I/usr/include/libavcodec -I/usr/include/libavformat
> -I/usr/include/libswscale -I/usr/local/src/grass64_release/dist./include -o
> OBJ./gsd_img_mpeg.o -c gsd_img_mpeg.c
> gsd_img_mpeg.c: In function ‘add_video_stream’:
> gsd_img_mpeg.c:69:21: error: ‘CODEC_TYPE_VIDEO’ undeclared (first use in
> this function)
> gsd_img_mpeg.c:69:21: note: each undeclared identifier is reported only once
> for each function it appears in
> gsd_img_mpeg.c: In function ‘open_video’:
> gsd_img_mpeg.c:161:5: warning: ‘avcodec_open’ is deprecated (declared at
> /usr/include/libavcodec/avcodec.h:3650) [-Wdeprecated-declarations]
> gsd_img_mpeg.c: In function ‘write_video_frame’:
> gsd_img_mpeg.c:218:15: error: ‘PKT_FLAG_KEY’ undeclared (first use in this
> function)
> gsd_img_mpeg.c: In function ‘gsd_init_mpeg’:
> gsd_img_mpeg.c:304:9: warning: assignment makes pointer from integer without
> a cast [enabled by default]
> gsd_img_mpeg.c:307:6: warning: assignment makes pointer from integer without
> gsd_img_mpeg.c:315:8: warning: assignment makes pointer from integer without
> gsd_img_mpeg.c:336:5: warning: ‘av_set_parameters’ is deprecated (declared
> at /usr/include/libavformat/avformat.h:1363) [-Wdeprecated-declarations]
> gsd_img_mpeg.c:341:5: warning: ‘dump_format’ is deprecated (declared at
> /usr/include/libavformat/avformat.h:1485) [-Wdeprecated-declarations]
> gsd_img_mpeg.c:350:2: warning: ‘url_fopen’ is deprecated (declared at
> /usr/include/libavformat/avio.h:278) [-Wdeprecated-declarations]
> gsd_img_mpeg.c:357:5: warning: ‘av_write_header’ is deprecated (declared at
> /usr/include/libavformat/avformat.h:1421) [-Wdeprecated-declarations]
> gsd_img_mpeg.c: In function ‘gsd_close_mpeg’:
> gsd_img_mpeg.c:442:2: warning: ‘url_fclose’ is deprecated (declared at
> /usr/include/libavformat/avio.h:279) [-Wdeprecated-declarations]
> make: *** [OBJ./gsd_img_mpeg.o] Error 1
> I went to /usr/local/src/grass64_release/lib/nviz and run 'make'.
> gcc -shared -o
> /usr/local/src/grass64_release/dist./lib/libgrass_nviz.6.4.3svn.so
> -L/usr/local/src/grass64_release/dist./lib -Wl,--export-dynamic
>  -L/usr/lib64 -Wl,-rpath-link,/usr/local/src/grass64_release/dist./lib
>  OBJ./change_view.o OBJ./cplanes_obj.o OBJ./draw.o OBJ./exag.o OBJ./lights.o
> OBJ./map_obj.o OBJ./nviz.o OBJ./position.o OBJ./render.o
> -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
> -lgrass_bitmap.6.4.3svn -lgrass_linkm.6.4.3svn  -lgrass_vect.6.4.3svn
> -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
>      -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn
> -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz      -lgrass_gis.6.4.3svn
> -lgrass_datetime.6.4.3svn -lz      -lgrass_dgl.6.4.3svn
> -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
> -lgrass_rtree.6.4.3svn  -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
>   -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn  -lgrass_dig2.6.4.3svn
> -lgrass_rtree.6.4.3svn  -lgrass_dgl.6.4.3svn -lgrass_rtree.6.4.3svn
> -lgrass_linkm.6.4.3svn -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn
> -lgrass_datetime.6.4.3svn -lz      -lgrass_dbmibase.6.4.3svn
> -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz       -L/usr/lib
> -lgdal1.7.0 -lgeos_c   -ltiff   -lavutil  -lavcodec  -lavformat
>  -lgrass_sites.6.4.3svn -lgrass_datetime.6.4.3svn -lgrass_dbmibase.6.4.3svn
>  -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn
> -lgrass_datetime.6.4.3svn -lz     -lgrass_vect.6.4.3svn
>   -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn   -lgrass_g3d.6.4.3svn
>  -lgrass_ogsf.6.4.3svn -lgrass_bitmap.6.4.3svn -lgrass_linkm.6.4.3svn
>  -lgrass_g3d.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
>   -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn   -lgrass_vect.6.4.3svn
>   -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn   -lm   -lSM -lICE -lX11
> -L/usr/include/GL  -lGL  -L/usr/include/GL  -lGLU
> /usr/bin/ld: cannot find -lgrass_ogsf.6.4.3svn
> collect2: ld returned 1 exit status
> make: ***
> [/usr/local/src/grass64_release/dist./lib/libgrass_nviz.6.4.3svn.so] Error 1
> I don't know how to deal with these errors. Is there anyone can help me?
> Thank you so much.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
