Re: Re: [GRASS-dev] Applying for write access to the Addons-SVN repository
stepan.turek stepan.turek at seznam.cz
Thu Apr 12 06:35:33 EDT 2012
Hello,
WMS-c or WMTS would be possible to implement into r.in.wms2.
After finishing standard wms support implementation  for GRASS and SAGA I
will take a deeper look at it.
Stepan
---------- Původní zpráva ----------
Od: Vincent Bain <bain at toraval.fr>
Datum: 7. 4. 2012
Předmět: Re: [GRASS-dev] Applying for write access to the Addons-SVN
repository
"A pretty good news in fact.
Stepan, do you plan to cope with cached services (WMS-c) ?
I mean, here in France IGN provides a WMS which is quite uneasy to
request, r.in.wms fails. One can have a look here :
http://depot.ign.fr/geoportail/api/doc/developpeur/wmsc.html
(http://depot.ign.fr/geoportail/api/doc/developpeur/wmsc.html)
For my personal purpose I wrote a bash routine (not much portable as is)
to retrieve orthoimagery tiles the right way using the current region
settings. As wms-c is not considered a standard ogc protocol, it may not
be worth trying to integrate multiple constraints to the module, what's
more they probably* vary from one provider to another (tile sizes,
available resolutions, point of origin, and so on) ; perhaps a wiki
HowTo in this case would already be helpful for french users ?
Yours,
Vincent.
__
*don't really know, I'm not a web mapping specialist
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120412/f0ecbb3c/attachment.html
