[GRASS-dev] Applying for write access to the Addons-SVN
repository
Vincent Bain
bain at toraval.fr
Thu Apr 12 06:49:51 EDT 2012
Stepan,
by lack of time I didn't yet test your new module, but I see the user is
asked to fill in the projection system of layers he requests. Am I
right ? I just wonders if you had tried to implement the ability to
self-evaluate this parameter: getting that information is possible via a
GetCapabilities request, isn't it ?
Thanks for your work,
good luck.
Vincent.
Le jeudi 12 avril 2012 à 12:35 +0200, stepan.turek a écrit :
> Hello,
> WMS-c or WMTS would be possible to implement into r.in.wms2.
> After finishing standard wms support implementation for GRASS and
> SAGA I will take a deeper look at it.
> Stepan
> ---------- Původní zpráva ----------
> Od: Vincent Bain <bain at toraval.fr>
> Datum: 7. 4. 2012
> Předmět: Re: [GRASS-dev] Applying for write access to the Addons-SVN
> repository
> A pretty good news in fact.
> Stepan, do you plan to cope with cached services (WMS-c) ?
> I mean, here in France IGN provides a WMS which is quite
> uneasy to
> request, r.in.wms fails. One can have a look here :
> http://depot.ign.fr/geoportail/api/doc/developpeur/wmsc.html
> For my personal purpose I wrote a bash routine (not much
> portable as is)
> to retrieve orthoimagery tiles the right way using the current
> region
> settings. As wms-c is not considered a standard ogc protocol,
> it may not
> be worth trying to integrate multiple constraints to the
> module, what's
> more they probably* vary from one provider to another (tile
> sizes,
> available resolutions, point of origin, and so on) ; perhaps a
> wiki
> HowTo in this case would already be helpful for french users ?
> Yours,
> Vincent.
> __
> *don't really know, I'm not a web mapping specialist
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
