Re: Re: Re: [GRASS-dev] Applying for write access to the Addons-SVN repository
stepan.turek stepan.turek at seznam.cz
Thu Apr 12 07:39:24 EDT 2012
Yes, user have to insert EPSG number.
So far, It is implemented only getMap request, which is in responsibility of
the module r.in.wms2. In r.in.wms2 GetCap response is only printed in output
btw. there was bug in r.in.wms2 getCapabilities, i have just fixed it.
I want to implement parsing of GetCap request into wxGui. The wxGui utility
would parse getCap response and according to parsed values create dialog.
Then user would choose parameters for r.in.wms2 from the dialog of parsed
GetCap.
Thanks for feedback,
Stepan
---------- Původní zpráva ----------
Od: Vincent Bain <bain at toraval.fr>
Datum: 12. 4. 2012
Předmět: Re: Re: [GRASS-dev] Applying for write access to the Addons-SVN
repository
"Stepan,
by lack of time I didn't yet test your new module, but I see the user is
asked to fill in the projection system of layers he requests. Am I
right ? I just wonders if you had tried to implement the ability to
self-evaluate this parameter: getting that information is possible via a
GetCapabilities request, isn't it ?
Thanks for your work,
good luck.
Vincent.
Le jeudi 12 avril 2012 à 12:35 +0200, stepan.turek a écrit :
> Hello,
> WMS-c or WMTS would be possible to implement into r.in.wms2.
> After finishing standard wms support implementation for GRASS and
> SAGA I will take a deeper look at it.
> Stepan
> Datum: 7. 4. 2012
> Předmět: Re: [GRASS-dev] Applying for write access to the Addons-SVN
> repository
> A pretty good news in fact.
> Stepan, do you plan to cope with cached services (WMS-c) ?
> I mean, here in France IGN provides a WMS which is quite
> uneasy to
> request, r.in.wms fails. One can have a look here :
> http://depot.ign.fr/geoportail/api/doc/developpeur/wmsc.html
(http://depot.ign.fr/geoportail/api/doc/developpeur/wmsc.html)
> For my personal purpose I wrote a bash routine (not much
> portable as is)
> to retrieve orthoimagery tiles the right way using the current
> region
> settings. As wms-c is not considered a standard ogc protocol,
> it may not
> be worth trying to integrate multiple constraints to the
> module, what's
> more they probably* vary from one provider to another (tile
> sizes,
> available resolutions, point of origin, and so on) ; perhaps a
> wiki
> HowTo in this case would already be helpful for french users ?
> Yours,
> Vincent.
> __
> *don't really know, I'm not a web mapping specialist
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
(http://lists.osgeo.org/mailman/listinfo/grass-dev)"
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120412/44b14901/attachment-0001.html
