[GRASS-dev] g.mapsets syntax in G7
Martin Landa
landa.martin at gmail.com
Thu Apr 12 12:02:08 EDT 2012
`g.mapset` has currently several options to set/add/remove mapsets
from the search path
mapset Name(s) of existing mapset(s)
addmapset Name(s) of existing mapset(s) to add to search path
removemapset Name(s) of existing mapset(s) to remove from search path
I would suggest to change syntax of `g.mapset` to allow only one
operation when launching module.
operation=add,set,remove Operation to perform
Make sense to you?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
