[GRASS-dev] g.mapsets syntax in G7
Luca Delucchi lucadeluge at gmail.com
Thu Apr 12 13:14:54 EDT 2012
2012/4/12 Martin Landa <landa.martin at gmail.com>:
> Hi,
> `g.mapset` has currently several options to set/add/remove mapsets
> from the search path
>       mapset   Name(s) of existing mapset(s)
>     addmapset   Name(s) of existing mapset(s) to add to search path
>  removemapset   Name(s) of existing mapset(s) to remove from search path
> I would suggest to change syntax of `g.mapset` to allow only one
> operation when launching module.
> operation=add,set,remove Operation to perform
> Make sense to you?
yes, maybe the default operation should be add
> Martin
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
