[GRASS-dev] g.mapsets syntax in G7
Markus Metz markus.metz.giswork at googlemail.com
Thu Apr 12 14:14:09 EDT 2012
On Thu, Apr 12, 2012 at 7:14 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2012/4/12 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>> `g.mapset` has currently several options to set/add/remove mapsets
>> from the search path
>>       mapset   Name(s) of existing mapset(s)
>>     addmapset   Name(s) of existing mapset(s) to add to search path
>>  removemapset   Name(s) of existing mapset(s) to remove from search path
BTW, these options exist for g.mapsets, not for g.mapset.
>> I would suggest to change syntax of `g.mapset` to allow only one
>> operation when launching module.
>> operation=add,set,remove Operation to perform
>> Make sense to you?
> yes, maybe the default operation should be add
+1
Markus M
