[GRASS-dev] Emitting a Python exception instead of calling exit in GRASS
Sören Gebbert soerengebbert at googlemail.com
Sun Apr 22 10:37:26 EDT 2012
Dear devs,
while thinking about a high level Python interface based on the low
level ctypes interface a question raised in my mind:
Is it possible to raise a Python exception instead of calling exit in
case of a fatal error when using ctypes wrapped GRASS library
functions? So the calling module can gently exit, closing open
database connections and so on?
I am not a Python expert and know quite nothing about its C
implementation of exception handling,
but it seems to me that this will be quite hard to use in GRASS,
because it seems to me that Python C functions like
PyErr_SetString()[1]
simply set an error indicator which must be evaluated by the calling functions?
In the vtk-grass-bridge i am using setjmp/longjmp to shut down the
calling module gently in case of a fatall error. Does anybody know how
to do something similar with exceptions in the ctypes interface?
Something like a TRY/EXCEPT implementation in libgis using
setjmp/longjmp?
Untested and maybe wrong Example:
In libgis:
extern jmp_buf stack_buffer;
extern const char* error_message;
int TRY(){
    return !setjmp(stack_buffer);
The error function set with G_set_error_routine(error_handler):
static int error_handler(const char *msg, int fatal)
    if (fatal == 0)
        fprintf(stderr, "%s\n", msg);
        return 1;
    else
        fprintf(stderr, "\n############## Exceptiont called ###########\n");
        error_message = msg;
        longjmp(stack_buffer, 1);
    return 1;
Using this in Python:
import grass.lib.gis as libgis
import grass.lib.raster as libraster
if libgis.TRY():
    fd = libraster.Rast_open_old(name, mapset)
else:
    # Clean up
    raise Exception(libgis.error_message)
does this makes any sense?
Thanks for any suggestions and best regards
Soeren
[1] http://docs.python.org/c-api/exceptions.html#PyErr_SetString
