[GRASS-dev] Re: code examples
Carlos Grohmann
carlos.grohmann at gmail.com
Mon Apr 23 13:14:26 EDT 2012
Hi.
Thanks for the answers, but I feel I need to explain myself a bit better.
I'm not looking for example codes (like r.example or v.example), I'm looking for _real_ code,
but more specifically, some piece of code that was wrote in a way that my look confusing
to a beginner programmer, but that is well explained in the comments.
for instance, (python):
> actual code:
# remove file extensions, join all names and remove white spaces (all at once)
self.nomMerge = 'Merge_' + ''.join(['' if i == ' ' else i for i in '_'.join([i[:-4] for i in nomMerge])]) + '.txt'
> explained in comments:
# this line is the same as:
# a = [i[:-4] for i in nomMerge] # remove file extensions
# b = '_'.join(a) # first join
# c = ['' if i == ' ' else i for i in b] # remove white spaces
# d = '_'.join(c) # second join
# e = 'Merge_' + d + '.txt'
I don't speak C or C++, but I know this kind of situation can happen, so
I'm looking for examples such as the above but in C, or C++
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com (http://carlosgrohmann.com/)
________________
Can’t stop the signal.
Sent with Sparrow (http://www.sparrowmailapp.com/?sig)
On Sunday, 22 April 2012 at 01:02, Carlos Grohmann wrote:
> Hello devs,
> I was wondering if you could provide me with an example of GRASS' code that would look
> obscure and complicated to a non-experienced programmer, but that at the same time is
> nicely explained by the comments (maybe with some pseudo-code)?
> I'm looking into that with teaching and (it's a long shot but..) academic intents.
> thanks
> ________________
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120423/02ac55b9/attachment.html
