[GRASS-dev] [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Wed Aug 22 00:29:51 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment(by mmetz):
Replying to [comment:42 glynn]:
> Replying to [comment:41 martinl]:
> > just to sure what we want...
> > python scripts should be executable from
> > 1. cmd
> > 2. msys
> > 3. wxGUI
> In 7.0, MSys isn't required, and supporting it shouldn't be GRASS'
responsibility (I don't know of any other Windows application which goes
out of its way to support being used from MSys). If it is supported, it
shouldn't be at the expense of native operation.
> > without need to define extension, eg.
> g.manual
> > should be possible to execute somehow. But AFAIU, in this case Windows
doesn't know that python should be called, right?
> No, Windows supports this. Installing Python associates the .py
extension with the Python interpreter.
WinGRASS does not install python, nor numpy, scipy, or wxpython. These are
all bundled with wingrass but not installed the Windows way. Therefore the
system does not know that there is something like python.exe and the
system does not know what to do with .py files. IIRC, a decision was made
some time ago to not install python the Windows way together with wingrass
because that could interfere with already installed python versions.
WinGRASS is currently compiled against osgeo4w python and related
packages, i.e. msys packages. It looks like that either wingrass installes
python system-wide, the Windows way, or wingrass does not require a
system-wide python and uses its own python, but then some .bat wrapper
like
@"%GRASS_PYTHON%" "%GISBASE%/scripts/g.manual.py" %*
(see [comment:35 martinl]) would be needed. Is there another solution for
the case that wingrass should work without a system-wide python?
> Adding .PY to the PATHEXT environment variable allows Python scripts to
be run without the extension (in the same way as .bat, .cmd, etc). That
will work for anything which uses the shell (system(), Python's subprocess
module, batch files, etc).
Even if the system knows nothing about any python.exe?
BTW, there is another strange side-effect. Addon scripts for GRASS 7 do
not execute. Because of a some ugly hack it is possible to get the GUI for
an addon script (--interface-description works), but clicking on run
returns an error that the module is not found. This happens on some, not
all windows systems.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:43>
