[GRASS-dev] [GRASS GIS] #1616: WXGUI selecting to render a map and map selection bind to same event in layer manager
trac at osgeo.org
Sat Aug 25 12:00:48 PDT 2012
layer manager
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by annakrat):
There are more problems. One of them is that layer selection and changing
checkbox state should be independent which was not working properly. This
issue should be fixed in r52913 (grass 7). Please could you test it works
also on Windows? I can then backport it.
Other issue is related more to wxPython/wxWidgets. When you click outside
the layer name it triggers the change of checkbox state. This behaviour is
the same like in wxPython demo. I am not sure if there is some workaround
for this.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1616#comment:1>
